WRITER_TYPE Error Ifc to CityGML
  • Jun 7, 2018 2:42 PM UTC
  • 5 replies
  • 103 views
I am am trying to convert a IFC-file into a CityGML-file. For inspiration I am relying heavily on the intermediate guide for BIM to gis. Now when I am trying to convert the IFCDoors entities into CityGML doors i get the following error:
Type of writer to use was not specified (WRITER_TYPE was not found)
I have to the best of my knowledge not changed the writer in any way except for the output-file path and the projection system. Every other geometry I am using seems to konvert nicely.
So my questions are as follow:
What does the error mean?
How can I solve it?
Thanks in advance :D
Best answer by daveatsafe
Hi @hadhafang,
Would you mind providing a copy of the log file showing the error, and a copy of your workspace? The log file will provide more information on the error.
daveatsafe
Forum|alt.badge.img+24
  • Jun 7, 2018 4:14 PM UTC
Hi @hadhafang,
  • Jun 7, 2018 4:25 PM UTC
Hi @hadhafang,
Where an how can I do so?
daveatsafe
  • Jun 7, 2018 4:28 PM UTC
Hi @hadhafang,
If you click on the paper clip icon in the comment dialog, you can attach files to your comment.
  • Jun 17, 2018 8:51 PM UTC
Hi @hadhafang,
Sorry for the late answer. I am unfortunatly not at liberty to share the data file. However I have copied the log into two files:
  1. log1runningproperly.txt
  2. log2ifcdoorenabled.txt
Log 1 is the log where I have disabled the door and the workspace will excecute
Log 2 is the log where IFCDoor is enabled and i get "Type of writer to use was not specified (WRITER_TYPE was not found)"-error.
daveatsafe
  • Jun 18, 2018 6:23 PM UTC
Hi @hadhafang,
From the error in the log file, it appears that the IfcDoor feature has a line geometry instead of the surface expected by the CityGML writer.
Please check your workspace to see why the IfcDoor is getting line geometry.
