Writer: ESRI Geodatabase
  • Aug 21, 2013 7:23 PM UTC
  • 30 views
sigtill
Forum|alt.badge.img+25
Trying to read:
http://docs.safe.com/fme/html/FME_ReadersWriters/Default.htm#geodatabase/Writer_Directives_EntGeodb.htm
To figure out what the parameter setting: Validata Features to Write does. However I can not see any documentation on it. I "assume" it will only write Valid Features to the database (ie - features that have all Attributes) and that it will FAIL and ROLL BACK once it meets a feature which misses an Attribute in the feature (that is not null)
Best answer by fmelizard
This parameters is used for domein validations, sub types are automatically validated but for domein validations you can use this parameter.
fmelizard
Forum|alt.badge.img+22
  • Aug 22, 2013 6:46 AM UTC
