Write to fixed width text file
  • Jun 21, 2021 7:00 AM UTC
  • 151 views
I use FME to get data from a database and have to write it to a text file with a fixed width. For example:
Streetname (24 characters) number (5 characters) City (24 characters) postal code (6 characters)
(+ like 25 more)
StreetA        00011    CITYAA      1111AB
StreetB        00021    CITYBA      1234AB
I have tried to use the format fuction in the attribute manager but only got the format back like : 10s24s5s6s
Input: @Format(24s,@Value(lokatie_straat))@Format(5s,@Value(lokatie_huisnummer))@Format(7s,@Value(lokatie_huisnummer_toevoeging))@Format(24s,@Value(lokatie_woonplaats))@Format(6s,@Value(lokatie_postcode))
How can I make a file with the above format? (I have no influence on the format used.)
debbiatsafe
Forum|alt.badge.img+24
Hi @sisi_​
Try the @PadRight() (or @PadLeft()) functions. Based on the documentation, the @Format() function only works on numbers.
  • Jun 22, 2021 7:42 AM UTC
Hi @sisi_​
@debbiatsafe​ Thank you! It worked perfectly :)
