Will the OS (GB) MasterMap Reader be updated to reflect the changes in schema v9?
From Spring 2016 OS will be upgrading OS MasterMap Topography Layer data to the version 9 schema:
https://www.ordnancesurvey.co.uk/business-and-gove...
Will this have any impact on the OS (GB) MasterMap Reader in FME?
Best answer by mark_f
@kewsg
If you look at the schema in the FME installation folder, you should see it is already at version 9
e.g.
FME 2015
..\\FME2015.1\\xml\\schemas\\os\\mastermap
Forum|alt.badge.img+31
  • June 1, 2016
The sample data that OS have available can be read by both the OS(GB) MasterMap reader and the GML reader
  • June 1, 2016
@kewsg
e.g.
FME 2015
  • June 3, 2016
Thanks for clarifying
