Why do I only get attributes, but no geometry when using the WFS Reader and File Geodatabase Writer?
  • Aug 24, 2017 5:28 PM UTC
  • 6 replies
  • 328 views
fmelizard
Forum|alt.badge.img+22
  • Aug 24, 2017 5:33 PM UTC
Hi @heidirk, can you confirm that geometry is being sent to the File Geodatabase?
  • Aug 24, 2017 5:44 PM UTC
Hi @TiaAtSafe, I only have a reader and a writer and the geometry is definitely not making it to the File Geodatabase and I don't think it's making it out of the reader. When I run with full inspection and look at the features between the reader and writer, they have no geometry. Is there another way to check?
fmelizard
  • Aug 24, 2017 5:51 PM UTC
Hi again @heidirk, when I read in the data from your WFS URL, I don't see any geometry being read in. Are you sure that there is geometry on the input?
  • Aug 24, 2017 5:59 PM UTC
@TiaAtSafe I did verify that there is geometry at the Rest endpoint of the service,
https://itportal.decc.gov.uk/arcgis/rest/services/OGA_Public_WGS84/OGA_Quadrants_WGS84/MapServer/.
I don't know how to confirm that the same is available in the WFS.
danilo_fme
Forum|alt.badge.img+58
  • Aug 24, 2017 6:36 PM UTC
Hi @heidirk,
And if you Read the KML link: KML with FME?
Thanks,
Danilo
bruceharold
Forum|alt.badge.img+20
  • Aug 24, 2017 8:07 PM UTC
