WFS Reader - XML Filter Expressions - Tutorial
  • September 11, 2023
  • 5 replies
  • 433 views
oliver
Hi there!
I want to let you know, that I'm writing a new tutorial covering XML Filter Expressions in WFS Reader:
https://olivers-expression-lab.gitbook.io/filter-expressions-in-fme/
The basics are done.
Please let me know, if it works for you and escpecially if not!
Best regards
Oliver
nielsgerrits
Forum|alt.badge.img+54
Great piece, XML Filter Expressions can be challenging.
Since ChatGPT this has become a lot easier. maybe this is the more efficient way to go? (Safe implementing AI assist.)
oliver
  • September 13, 2023
Hi Niels,
thank you for your feedback!
Yes, an assistant would be really helpful.
But I'm not sure if ChatGPT would be necessary.
I assume, that it will use this amongst others
https://www.mapserver.org/ogc/filter_encoding.html
But AI is not really necessary.
FME knows anything which is necessary to feed an assistant only by sending 2 requests to the WFS in question:
- GetCapabilities
- GetFeature
I've an idea im my mind.
I will write it down and place an idea.
Best regards
Oliver
chaitanyamalla
oliver wrote:
Hi there!
I want to let you know, that I'm writing a new tutorial covering XML Filter Expressions in XML Reader:
Best regards
Oliver
Wow, just amazing. Thanks for sharing your great tutorial Oliver. I have learn’t about WFS links and how to use them in FME. Keep posting such amazing content.
Greetings,
Chaitanya Malla
Forum|alt.badge.img+50
Thanks for sharing this @oliver! I recently dove into XML filter expressions because a client asked for it and was frustrated about the lack of documentation, but this really helps a lot!
oliver
  • August 19, 2024
Thanks Hans, I’m really honored!
I made some additions. Maybe they’re also helpful ? 😎
Just let me know!
Best regards
Oliver
