Using S3 lister and downloader for CSV processing through FME server
  • Mar 7, 2019 7:04 AM UTC
  • 74 views
Created a workbench to download and save on local disk, from S3 to local disk and read csv using featureReader works fine with FME Desktop (20181203 - Build 18578 - WIN64). Publishes same workbench to FME Server with additional parameters like file name etc and run through post call, failed to process csv file with following message:
CSV reader: The keyword _DELIMITER has an invalid value: 'auto'. It must be a single character that is representable by one byte in utf-8BADNEWS: A fatal error has occurred. Check the logfile above for details (dynaread.cpp:199)A fatal error has occurred. Check the logfile above for details(dynaread.cpp:199).
How do I track this fatal error ?
  • Mar 7, 2019 8:38 AM UTC
What is the version of the FME Server? Is it possible that your FME Desktop is more recent than your FME Server?
  • Mar 7, 2019 11:15 PM UTC
Thanks for the response. @david_r Version for FME Server 2018.0.0.3 - Build 18305 - win64. Does this make difference with version mismatch having feature reader and S3 transformers. Feature reader is reading CSV with specific fields in it exposed through Generic Port
  • Mar 8, 2019 8:01 AM UTC
It's difficult to tell if this is the problem here, but in general I would very much recommend never using a more recent FME Desktop when publishing to FME Server, it can create a lot of issues that may be hard to debug.
