I work for a city entity and have a federated login. I'd like to connect to ArcGIS Online in FME Data Inspector so that I can use a specific basemap. Is this possible? How can I format my credentials here?Thanks!
Using ArcGIS Online federated/enterprise account to connect to basemaps in FME Data Inspector
Best answer by JennaKAtSafe
Hi @carmijo, what version of FME Desktop are you currently using? To format your credentials they are your regular username/password you use to log into your ArcGIS Online. You should also be able to select an existing ArcGIS Online Web Connection.
