Using a cursor. The error number from ArcObjects is: '-2147216072'
  • Mar 15, 2013 2:52 AM UTC
  • 1143 views
Hello:
I have re-created some layers with the exact same parameters in SDE, to run a final test of some workbenches.
During execution, I get this error:
n error occurred while attempting to insert a row into the table <table> using a cursor. The error number from ArcObjects is: '-2147216072'
This seems to be not clearly documented by ESRI. Does anyone know what this could be related to?
Many thanks,
  • Mar 15, 2013 4:28 AM UTC
Found the problem... Corruption in the SDE Registry.
Solution: Delete the faulted objects with ArcCatalog
george
Participant
  • Participant
  • Oct 8, 2014 12:31 PM UTC
Hi canpernano,
We are experiencing similar issues recently.
Could you explain:  what do you mean by "Corruption in the SDE Registry"?
what is "the faulted objects"?
We are using SDE10.2/SQL server 2014.
Thank you in advance.
George (geoshi@gmail.com)
I encountered similar type of issue with FME 2014 & ArcGis Desktop 10.3. could you guys please tell / suggest me how to resolve this issue?
Thanks,
Ravi Kumar
mark2atsafe
Forum|alt.badge.img+59
Thanks,
Ravi Kumar
Have you checked the solutions on this page?
https://knowledge.safe.com/articles/525/geodatabase-direct-connect-returning-error-tns-cou.html
