Within the User Parameters I have added the option to Select a File.
More specific the user has the option to select a Geodatabase (Items to Select).
When the user has selected the Geodatabase, I like to have the user also select the database of his/her own choice within that Geodatabase. Is there a way to configure that?
Best answer by harmen
Found the answer shortly after I've posted the question ;-)
...When the user has selected the Geodatabase, I like to have the user also select the database of his/her own choice within that Geodatabase. Is there a way to configure that?
I think you mean dataset or featureclass instead of database. But I do not know of a way to do this other than with predefined values.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
