Turn off license borrowing on FME Desktop
  • Oct 7, 2016 11:28 AM UTC
  • 149 views
sigtill
Forum|alt.badge.img+25
Is it possible to turn off / disable the "Borrow license" on FME Desktop? Or limit the number of days?
Best answer by david_r
In the directory where you keep your "safe.lic" file, create a new text file named "safe.opt" that contains the following line:
BORROW_LOWWATER FME 1
The number should be modified to reflect the minimum number of non-borrowed licenses that you'll allow. If the number is equal to or larger than the number of available licenses, borrowing is effectively disabled.
To set the maximum borrow duration, use the following setting:
MAX_BORROW_HOURS FME 72
This will set the maximum borrow period to 3 days (72 hours).
You can even use both settings together if you put them on separate lines in safe.opt.
  • Oct 7, 2016 12:18 PM UTC
  • Oct 7, 2016 12:48 PM UTC
Documentation: FlexServer\Documents\LicenseAdministration.pdf
sigtill
  • Oct 7, 2016 1:17 PM UTC
Great, thanks david! Didnt find that page after a quick google.
  • Oct 7, 2016 2:40 PM UTC
Just to add: By default it is (currently) not possible to set a maximum borrow period to more than 30 days (720 hours).
