Trigger FME workspace when ArcSDE is edited by separate system
  • September 7, 2016
  • 34 views
I have a feature class stored in an ArcSDE database which is edited by a couple of users via a web application. I want to push this information to a separate postGIS database. It’s important that the new/edited/deleted objects are pushed to the postGIS as quick as possible.
So, I’m wondering if it’s possible to do this via FME Server? Are there any features/tools for “listening” to a database, and execute a small workspace each time the database is edited (or something similar)?
Best answer by itay
Maybe this serie of articles can help.
https://knowledge.safe.com/articles/806/push-data-out-of-databases-to-fme-server-in-real-t.html
itay
Forum|alt.badge.img+17
  • September 7, 2016
steveatsafe
Forum|alt.badge.img+12
itay wrote:
Yes... the quickest way would be to use a trigger as indicated by the article Itay has shared. You could have a separate table in the same database that stores any updates history. When an update occurs the trigger fires... pushing to the FME Server and to this history table.
As a backup it might make sense for a schedule task that runs in the evening to check that the history table updates were all processed and change a flag in the history table. This would at least catch those times when a network hiccup occurs.
