I have a set of records that read via SQLExecutor which includes a timestamp field (driver_date). This seems to be stored a “buffer” datatype.
I don’t seem to be able to explode this field using the DateTimeExploder as it can’t autodetect the timestamp value as a date/time value.
I’ve tried including a DateTimeConverter, but get the same result. Is there someway to convert the timestamp from “buffer” datatype to datetime?
