Has anyone ever had the need to specify which sqlnet.ora file FME uses?
Unfortunately, I need to use 2 different ones to access various Oracle databases and FME does not like the one I use mainly. I have tried hacking about with both version to merge them but then I have FME not working or TOAD not working, or in some cases neither!
Any suggestions would be great as I am fed up having to keep swapping over :(
