Spatial filter not working against SDE reader.
  • Feb 14, 2014 5:37 PM UTC
  • 62 views
tbs_gis_team
Forum|alt.badge.img+3
I am trying to filter SDE database with spatial filter and it is not working. It works fine with a clipper, but I am not wanting to clip the data. I used this before with an FDO connection and it worked fine.
Thanks,
Chad
fmelizard
Forum|alt.badge.img+22
  • Feb 14, 2014 8:11 PM UTC
Hi Chad,
How are you applying the spatial filter? Via the transformer or the writer ?  Also have you tried the spatial relator?
tbs_gis_team
  • Feb 17, 2014 2:38 PM UTC
I am using it in the spatial filter transformer, we are passing a bounding box through the filter, linked to our online portal. This works fine when we are connecting to the data through FDO connect. We are migrating to Arc SDE and it will not work with the spatial filter, but will work with a clipper. I need both because sometimes we do not want the data clipped.
Thanks,
Chad
