Select only certain values in excel spreadsheet column
  • Jun 21, 2018 10:28 AM UTC
  • 50 views
simonhume
Forum|alt.badge.img+7
Hi
Can someone advise me what the easiest method there is to select only certain records from an excel spreadsheet, based on one column?
I have a simple excel spreadsheet listing bin deliveries to addresses as individual cases from our CRM system. One of the columns is whether the case is Open or Closed
One of my FME workspaces is configured to map all these into SHP format, which i've succesfully done
The other workspace now needs to also map these, but only where the case is Open.
I've tried the Attribute based Transformers, but can't get the correct output
Any help much appreciated
thanks
Simon Hume
Best answer by redgeographics
You could use the Tester or TestFilter to do that.
Forum|alt.badge.img+63
simonhume
  • Jun 21, 2018 11:33 AM UTC
@redgeographics
thanks for your prompt answer, the workspace is now working fine
Simon Hume
