Resources on writing features to databases
Hi FMEer's!
Can someone kindly point me to tutorials/webinars of where the workbench is writing particularly large amounts of data to spatial and non-spatial databases? I have many models that write to Oracle databases, SQL Server, ArcSDE etc. However, I find that the moment we start writing 100's of thousands of records it is quite slow. It's generally quicker to import a table into one of the databases and do the truncate and load through a database management software.
Some of the methods I use in FME are:
- Change detection and use FME_DB_OPERATION = Insert or Delete (Not sure really how to use the Update)
- Truncate table and insert (Use this when the table is massive and change detection is just not feasible)
- Write to ESRI file geodatabase first and then copy to ArcSDE
Any help is much appreciated, I just want to make my models more efficient!
Kind regards,
Kam
trentatsafe
  • October 4, 2018
Hello @kam,
Some resources covering the topics of databases can be found at the following links:
SQL Server: https://knowledge.safe.com/articles/32420/tutorial-getting-started-with-microsoft-sql-server.html
Updating Databases: https://knowledge.safe.com/articles/34351/updating-databases.html
Mastering Spatial Databases(Oracle): https://knowledge.safe.com/articles/44492/mastering-spatial-databases.html
Extracting differences from an ArcSDE Geodatabase: https://knowledge.safe.com/articles/30729/tutorial-extracting-differences-from-an-arcsde-geo.html
Those are just some of the articles currently posted on the Knowledge Centre. You may also find additional help from existing questions that have been asked and answered by the public. If you have a specific question as well, you can post it. FME users are very helpful in providing suggestions and tips on how you might be able to accomplish a specific workflow!
I hope that helps!
ravenkopelman
In general I'd expect pure insert mode to be much faster than update/deletes, but one concrete suggestion is to make sure you have an index on whatever column(s) you are keying your updates and deletes on.
mark2atsafe
Forum|alt.badge.img+43
  • October 4, 2018
Hi @kam Coincidentally I'm just starting on a short article about making database updates. So keep an eye out as it'll be online in the next few days.
