Replace commas within quotes when using CSV Reader
sunsilk11
Hi I have a CSV file with X,Y coordinates. I am loading this to a point feature class. However the XY coordinates sometimes come in quotes and have a comma, e.g.
GLOUCESTERSHIRE,ST BRAIVELS COMMON,GL15 6SD,"355,280","203,644"
Any suggestions what's the best way to handle this when using the CSV reader.
  • November 9, 2017
How is "355,280" to be interpreted?
As x=355.28 or as (x=355, y=280)?
dustin
Forum|alt.badge.img+31
  • November 9, 2017
Look into using the StringReplacer to remove unwanted characters.
sunsilk11
  • November 9, 2017
I need to interpret this as 355280
StringReplacer doesn't seem to work for me
  • November 9, 2017
Use a StringReplacer to replace the comma "," with an empty string.
Result:
csv2none.fmwt
dustin
  • November 9, 2017
@sunsilk11 - Could you attach your CSV file?
dustin
  • November 9, 2017
Result:
csv2none.fmwt
Similarly, you can use regular expression to remove both the quotes and comma at the same time, if that's what you are needing.
  • November 9, 2017
The CSV reader removes the double quotes by default, so it shouldn't be necessary. See the template workspace I uploaded.
If you are more comfortable with Excel, then you could also open the CSV file in Excel and change the data type of the X and Y coordinate fields to be number without a comma separator, then save it as CSV again,.. and read it into FME using the CSV reader without having to worry about it.
