Reading WFS fails in FME 2019, works in FME 2016
Like a poster who previously posted a similar question moving from 2015 -> 2016
My WFS reader has suddenly stopped working in 2019 moving from 2016.
I get the following error message
Sending HTTP 'GET' request to 'http://spatial.bom.gov.au:80/cgi-bin/mapserver/users/bomw0296/wxs?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=IDQ65470_wtr_lvl&NAMESPACE=xmlns%28%3Dhttp%3A%2F%2Fwww.opengis.net%2Fwfs%29&MAXFEATURES=1000', waiting for response ...
Parsing XML document 'http://spatial.bom.gov.au:80/cgi-bin/mapserver/users/bomw0296/wxs?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=IDQ65470_wtr_lvl&NAMESPACE=xmlns%28%3Dhttp%3A%2F%2Fwww.opengis.net%2Fwfs%29&MAXFEATURES=1000'
HTTP transfer error: 'Couldn't connect to server'
XML Parser error: 'Error in input dataset:'http://spatial.bom.gov.au:80/cgi-bin/mapserver/users/bomw0296/wxs?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=IDQ65470_wtr_lvl&NAMESPACE=xmlns%28%3Dhttp%3A%2F%2Fwww.opengis.net%2Fwfs%29&MAXFEATURES=1000' line:1 column:1 message:invalid document structure'
The XML Module halted on error, see the logfile for details
<WFS> An error occurred while reading a GetFeature response, to ignore the error and avoid losing the previously read features, set the WFS "Ignore GetFeature Error" parameter.  Total features downloaded: '0'
A fatal error has occurred. Check the logfile above for details
Is that a connection issue?   Even though it's working when setting up the reader and obtaining the schema?   If I paste that WFS request into a browser it is almost identical from what is requested from FME2016.  BTW that WFS is IP filtered.  If you try at your end you will be asked for a login.
danilo_fme
Forum|alt.badge.img+45
  • April 6, 2019
Hi @peterkt
I tried to access this WFS in the browser, but a loing and passwod was requered.
Do you have these informations?
Danilo
deanatsafe
  • April 6, 2019
I'm also presented with a password dialog like Danilo reported, and get a 401 Authorization Required error. You will need to add login credentials to FME's WFS reader settings in order to read features from this WFS.
It's important to remember that just because your browser doesn't show you a login doesn't mean FME can access the URL. It may be that you logged in with your web browser some time in the past and your browser remembers the login / authentication. FME does not automatically inherit this from your browser.
One way to test your browser to see if there is a login requirement is: try another browser (say IE if you normally use Chrome) or try a new private window which won't make use of any exiting cookies. In this case it is clear that FME requires security credentials, and if you were to try FME 2016 on the same WFS server you would have similar problems.
For more info on how to troubleshoot a WFS connection see: https://knowledge.safe.com/articles/19452/troubleshooting-wfs-errors.html
  • April 24, 2019
That service has IP filtering and usually works without a password. I added the login details and it works now.
Was able to find solution after I was supplied with alternative login details that didn't work with our IP and using the details it worked.
So something might be happening with IP address when using FME2019. But whatever the reason it works by filling in the details.
cwinfield
Participant
  • Participant
  • October 21, 2019
This is still an issue for me - any workspace using a WFS reader no longer works in 2019 or 2019.1, absolutely fine in 2018.0.
All run on the same machine using the same workspace, the only difference is the version of the software.
Can we get this looked at please - I've had to re-install 2018 to get updated data and its a pain having so many version of the same software on the same machine (using 32 and 64 bit versions as well)
trentatsafe
  • October 21, 2019
Hello @cwinfield
Are you able to share the workspace or the WFS Server URL itself that works in 2018 but does not in 2019?
If you would prefer not to share it on the forums, you could create a case here: https://www.safe.com/support/report-a-problem/ and we can take a look to see exactly what is occurring.
  • December 5, 2019
We are having the same issue, i.e. WFS reader works in 2018 but not 2019. Has any progress been made on resolving this?
-- sorry, just re-tested using 2019.2 and the problem is resolved.
geoal
  • December 5, 2019
Hy !
Same here !
I have a Wfs Connection(User&pw known) which works on 2017 but not on 2019 !
Always getting:
HTTP transfer error: 'SSL connect error'
trentatsafe
  • December 5, 2019
geoal wrote:
Hy !
Same here !
Always getting:
Hi @virtual
Ca you try the latest 2019.2 release and let me know if you are still encountering the issue?
