Reading Multiple Shapefiles from AWS with Shapefile Reader
  • Jan 17, 2019 6:59 AM UTC
  • 111 views
In regards to my previous question, I have tried finding how to read shapefile from AWS directly and read it (though seems to be quite slow). This possibility can neglect the use of multiple WorkspaceRunners(and I am still not sure how to use that)
shp reader- Select file from web- Browse S3- Authenticate- Choose shapefile.
my case:
C:\PATH\ABC\ABC_Q1.SHP
C:\PATH\ABC\ABC_Q2.SHP
C:\PATH\ABC\DEF_Q.SHP
C:\PATH\ABC\GHI_Q2.SHP
So, I can basically select 1 shapefile and process it at one go but really not sure about reading multiple files
in one go.
S3 path: fme://amazon-s3/ABW_C_Q4.zip?id=prithvi-output%2FqualityLevel%2FABW%2FABW_C_Q4.zip&connection=parashas%20Amazon%20Web%20Services
Tried using * in place of ABW_C_Q4 and ABW but doesn't really help.
srg
Forum|alt.badge.img+10
  • Jan 17, 2019 8:37 AM UTC
@dewan
If you are looking at reading merged datasets, check this link:
Merging Similar Datasets
hope that helps
happy fme-ing :-)
srg
  • Jan 17, 2019 8:50 AM UTC
@dewan
hope that helps
happy fme-ing :-)
srg
I am looking to fetch the data from AWS, not from the local drive(just below the Select Multiple Files/Folders).
