Reading metadata from an ArcSDE Feature Class
  • Nov 23, 2012 12:59 PM UTC
  • 135 views
I want to map the version last updated date from the metadata to a new field in the feature class.
When you save a feature class as an ESRI layer file it also creates an xml file in the same location.
Previously I would locate the feature class as a layer file saved in my local directory then read in the XML file using an XML reader, flatten the metadata and set the elements to match to 'metadata'
Then I can easily locate the attribute that contains the version date etc - and map this right over to a new field in a feature class.
But now where I have feature classes in SDE not saved as layer files I was wondering if there was any way of following this same process? How do I read that XML and after reading it, how would I carry out the xml flattening and elements to match when it is not using an XML reader?
Thanks
Best answer by conterrauta
have you seen the parameter "FEATURE_READ_MODE" of the SDE Geodatabase Reader? You can set it to METADATA (default is Feature).
Kind regards
Uta
  • Nov 25, 2012 6:39 PM UTC
Kind regards
Uta
  • Nov 26, 2012 10:40 AM UTC
Hi Uta,
Can you be a little more specific?
After i use a SDE geodatabase reader and set the feature read mode to metadata. How do i pull out specific metadata from that feature class?
  • Jul 16, 2014 5:21 PM UTC
Is there a way to get xml metadata from an enterprise SDE?
