Read file-gdb on google drive
  • Jul 1, 2018 2:15 AM UTC
  • 6 replies
  • 160 views
bo
Forum|alt.badge.img+10
Wonder if there is a direct way to use a reader or feature reader to read a zipped up fgdb stored on google drive. One options is to use google drive connector to download the fgdb to the local drive. Thanks!
Best answer by takashi
Hi @bo, You may not have privilege to write a file into the /home directory. Try downloading the file into a folder under the /Users/<username>.
  • Jul 1, 2018 4:13 AM UTC
Hi @bo, I think there is no way to directly read a dataset saved in any cloud storage service such as Google Drive. As you mentioned, download the dataset into local disk with the GoogleDriveConnector and then read it with the FeatureReader.
bo
  • Jul 2, 2018 4:43 AM UTC
Thank you, @takashi! Somehow, I ran into an issue of downloading the zip file using GoogleDriveConnector. Here are the configuration setting and the log file. I appreciate you taking a look at this and advise.
googledriveconnector.txt
  • Jul 2, 2018 5:29 AM UTC
I cannot find any wrong thing in your parameters setting. However, FME logged this warning.
WARN  |GoogleDriveConnector: Download of file "AZ_Centroids.gdb.zip" has failed.  Ensure Object ID is associated with a file and not a folder
The message seems to indicate that "AZ_Centroids.gdb.zip" may be a folder. Firstly check if "AZ_Centroids.gdb.zip" is actually a zip file.
bo
  • Jul 2, 2018 1:06 PM UTC
@takashi, the file is a gdb in the zip format. I also tried another .fmw file, the error msg was the same.
  • Jul 2, 2018 1:36 PM UTC
bo
  • Jul 2, 2018 1:47 PM UTC
Yes, it worked after I changed to the "/home/guob/Downloads" folder. Thanks!
