python caller error
soly
Forum|alt.badge.img+3
Hello ,
I got error from Python caller .
i would like to get all paths from start node to end node then I have written this script but I got Ann error .
could you please help me to fix this problem ?
import fme
import fmeobjects
import networkx as nx
class FeatureProcessor(object):
    def __init__(self):
        self.graph = nx.DiGraph()
        self.start_end_pairs = []
    def input(self, feature):
        start_node = feature.getAttribute('start_node')
        end_node = feature.getAttribute('end_node')
        arc_id = feature.getAttribute('arc_id')
        self.graph.add_edge(start_node, end_node, arc_id=arc_id)
        self.start_end_pairs.append((start_node, end_node))
    def find_all_paths(self, start, end):
        return list(nx.all_simple_paths(self.graph, source=start, target=end))
    def close(self):
        for start, end in self.start_end_pairs:
            all_paths = self.find_all_paths(start, end)
            for path in all_paths:
                feature = fmeobjects.FMEFeature()
                feature.setAttribute('path', ' -> '.join(path))
                self.pyoutput(feature)
Python Exception <AttributeError>: module 'importlib.resources' has no attribute 'files'
Error executing string `import fme
Error :
Factory proxy not initialized
PythonCaller_3 (PythonFactory): PythonFactory failed to process feature
PythonCaller_3 (PythonFactory): A fatal error has occurred. Check the logfile above for details
AttributeCreator_164_OUTPUT_-1_6456_Player (RecorderFactory): A fatal error has occurred. Check the logfile above for details
Thanks in advance
FME 2021
Best answer by david_r
Thanks @mark2atsafe !
@soly Looks like a problem with the networkx package (and not FME), you’re not the only one reporting this error, see e.g. https://stackoverflow.com/questions/78288036/module-importlib-resources-has-no-attribute-files Unfortunately I have no knowledge of this package, perhaps you could try to contact the package author.
  • August 14, 2024
When posting Python code, can you please format it using the “Code” block option:
Otherwise it’s very hard to read.
soly
  • August 14, 2024
@david_r
i do not have it .
  • August 14, 2024
That’s strange…
@mark2atsafe Do you know what’s going on?
mark2atsafe
Forum|alt.badge.img+43
  • August 14, 2024
david_r wrote:
That’s strange…
I don’t. I’ll look into that, but in the meantime I was able to edit the content to a code block by myself.
  • August 15, 2024
soly
  • August 16, 2024
@david_r  thanks .I will check it
