problem with excel output
  • Aug 2, 2013 8:50 AM UTC
  • 54 views
Bonjour,
Je ne parviens pas à faire des sorties excel, le format .csv fonctionne par contre.
J'ai le message suivant :
ADO Provider not installed or not compatible with FME architecture. Try installing Microsoft Access Database Engine (x64); follow this link for more information: http://www.microsoft.com/download/en/details.aspx?id=13255
Plugin 'XLS_ADO' was loaded, but a writer could not be created. Error was #1: A fatal error has occurred. Check the logfile above for details
  J'ai installé le plugin se trouvant sur le lien donné au dessus mais ça ne fonctionne toujours pas.
cordialement,
jy
  • Aug 2, 2013 8:51 AM UTC
sorry if i speak in french but the most important is that xls in out of order and i don't understand why.
fmelizard
Forum|alt.badge.img+22
  • Aug 2, 2013 8:52 AM UTC
My french is non existing, but I can kinda follow your question, did you restart the computer after downloading?
  • Aug 2, 2013 9:12 AM UTC
no, i'll try to restart the server
thanks
