Problem reading SHP-file when I run workbench on FME-server
  • Jan 3, 2017 4:17 PM UTC
  • 104 views
m_tengbrand
Participant
I have problem reading SHP-file when i run workbench on FME-server.
The same workbench runs without problem on the same machine in FME-desktop.
I get the error:
BADNEWS: Shape Reader: Failed to open dataset '\\\\sv101\\webkartor\\ValsProd\\PPL_PPL_Y.shp' which is neither an existing file nor directory (shapread.cpp:307)
(stftrans.cpp:275) - (..\\..\\..\\foundation\\framework\\engine\\reader.h:130) - (shapread.cpp:307)
  • Jan 3, 2017 4:33 PM UTC
You will probably have to configure your FME Server engines to execute as a domain user, as the regular service account doesn't have access to network resources.
See here: http://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Running_FME_Server_Engines_Under_Different_Account.htm
erik_jan
Forum|alt.badge.img+26
  • Jan 3, 2017 4:35 PM UTC
The FME Server service is running using a system account (default local system). That account probably does not have access to this network share.
Try using a network admin account to run FME server (see the properties of the service).
m_tengbrand
Participant
  • Participant
  • Jan 3, 2017 5:44 PM UTC
Thanks for the tips but i have checked that the FME server engine runs with my own user, the same as i use when i run the workbench successfully in FME-desktop.
Is it only the engine service that need a domain user?
The same workbench on the same FME-server has run successfully last week, on christmas day ;-)
