INFORM|Appending to existing table 'public.user_locations'...
WARN |PostgreSQL connection: Unknown type with OID 24635, treating as char(-1)
What does that warning means and what should I do to get rid of it?
Since I am about to load hundreds of GB of data, I just want to be sure everything will run smoothly after the upload...
Best answer by david_r
as far as I can tell, FME doesn's support PostgreSQL enum types. If you do not have to write to this field, you can probably safely ignore the warning.
If not you will probably have to experiment a bit to see if it is possible to work around it.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
