Postgres SCHEMA name as Published Parameter
I am trying to pass a schema name (database_username) for a postgis table as Publishes Parameter:
TYPE: Text
PROMT: Schemaname
After starting the workbench from a batch file with --test verden_test as parameter, I can see in the logfile that the parameter gets passed to FME:
2014-05-09 08:51:32|  19.5|  0.0|STATS |AttributeRenamer_3_OUTPUT -> verden_test.verkehr Correlator(TeeFactory)
But when FME tries to write into the database the logfileoutput is:
                       Features With No Schema defined
$(test).verkehr                                                       5
and the Database is empty.
I am using FME2013 SP2.
Any idea why the schema name is not used when writing to the database?
Thank,
Iris
  • May 9, 2014
Hi Iris,
In my quick test, I was success. In this image, is there any difference from your workspace?
                           Features Written Summary
verden_test.verkehr                                                          5
Total Features Written                                                       5
Takashi
  • May 12, 2014
Hi Takashi,
thanks for your answer.  The workbench looks the same, but the log file says something different:
AttributeRenamer_4_OUTPUT -> verden_test.verkehr Correlator(TeeFactory): Cloned 3 input feature(s) into 3 output feature(s)
|$(test).verkehr        3
|Total Features NOT Written                                                   3
|$(test).verkehr        3
|Total Features Written                                                       3
Iris
gio
Forum|alt.badge.img+15
  • May 12, 2014
maybe @Value($(test)) ?
is Takashi not using FME2014?
  • May 12, 2014
Yes, I was using FME 2014. But I was not able to reproduce the same error also with both FME2012 SP4 and FME 2013 SP4. Strange...
  • May 12, 2014
my FME Version seems to be the problem.  I am usually using FME2013 SP2.
I tried the same workbench with FME2012 SP2 and with FME2013 SP2.  It works fine in FME2012 SP2, but does not work in FME2013 SP2. So I guess I will just have to update my FME Version.
Thanks for getting me on the right track.
Iris
  • May 27, 2016
I have the same problem with 2015 Version... :/
I try to make Schéma_Postgis's name as published parametre and no results...
there is no error in log file..
Thanks for helping me.
