Point to dwg symbol
pauledrummond
Hi.
I am wanting to export a point layer (GEODATABASE FILE) to a .dwg using the pre-reconfigured block template symbols.
I have attempted using the DWGStyler but it will not pick up the templates symbols for some reason and just places a point. I have tried following https://community.safe.com/s/question/0D54Q000080hglVSAQ/replace-point-with-symbol-from-a-dwg but there is not quite enough detail on how to go about it.
Can someone please provide the parameters that I need to fill to get the symbol to a dwg file.
Thanks.
deanhowell
Forum|alt.badge.img+23
  • August 3, 2020
Hello @pauledrummond​ , have you set the autocad_block_name attribute?
This image is the settings from dwgstyler that we have done and the block creates as expected.
dwgstyler
pauledrummond
  • August 3, 2020
dwgstyler
Thanks for your response @deanhowell​ .
I have done the same although using an attribute for the Block Name. My Block name has spaces in it (WATER_Valve - Sluice). Do you think that may be an issue?
Paul
deanhowell
  • August 3, 2020
Paul
Hello @pauledrummond​ I am not sure but worth checking. If you have a sample file and dwg template, I would be happy to check for you?
pauledrummond
  • August 3, 2020
Paul
Thanks for that @deanhowell​ .
I would love to know what I'm doing wrong!
Regards, Paul
deanhowell
  • August 3, 2020
Thanks @pauledrummond​ I think I found the issue.
The shapefile has the block name attribute as StopValve-Sluice but that does not exist in your template. If I used a different one like WATER_Value - Sluice then it works (with spaces).
pauledrummond
  • August 3, 2020
Fantastic @deanhowell​ !
Thanks so much for your efforts. Really appreciated.
Regards, Paul
