Parsing XML properties properly
  • Apr 12, 2019 8:22 AM UTC
  • 45 views
Hello - part 2 of an XML thread.
I have a bunch of nodes in an XML document that look like this;
<nodes>
            <node>
              <properties>
                <property type="field_name">first_name</property>
                <property type="field_data">Ben</property>
              </properties>
            </node>
            <node>
              <properties>
                <property type="field_name">last_name</property>
                <property type="field_data">Potts</property>
              </properties>
            </node>
</nodes>
And I want to get those out as variables to use down the line in an FME workbench. At the moment I am relying on the order of them in a Test Filter (i.e. If @Value(_attr_name) = nodes.node{0}.properties.property{1} = first_name then put it on an output port of 'first_name') - however I hate relying on the order and I'm sure there is a better way of getting them out.
Any help would be much appreciated.
Ramo
  • Apr 12, 2019 12:58 PM UTC
If your goal is to extract two attributes called "first_name" with value "Ben" and "last_name" with value "Potts" from the XML document, the XMLXQueryExtractor might help you.
XQuery expression:
for $p in //properties
let $name := data($p/property[@type="field_name"])
let $value := data($p/property[@type="field_data"])
return fme:set-attribute($name, $value)
