output to oracle
  • Jun 24, 2013 1:15 PM UTC
  • 73 views
vki
Forum|alt.badge.img+8
I'm new to FME, so my question may be quite simple:
In ORACLE I would like to output the content of a table into a new table. Except for two attributes, the structure of new table is the same as the one of the input-table. The input-table has a field "Geometry" with the type "SDO_GEOMETRY" and the output-table has to have it too. (We don't have Oracle Spatial though).
I first defined a reader (format: Oracle Spatial Object) and tried to define a writer.
But what format do I have to choose for the writer? With oracle non-spatial I loose the geometry and with oracle Spatial Relational the geometry is no longer saved in an "SDO_GEOMETRY"-field, but in four new tables.
How could I do this (is it possible at all without oracle spatial)?
Many thanks in advance!
fmelizard
Forum|alt.badge.img+22
  • Jun 24, 2013 1:26 PM UTC
Have a look at the geometry replacer / geometry extractor, this way you can choose a geometry representation that can be saved in oracle non spatial.
Itay
  • Jun 24, 2013 1:41 PM UTC
if you do not need to access the geometries with other tools than FME, the easiest is probably to convert the geometries to OGC Well-Known Binary (use the GeometryExtractor) and save them in a regular Oracle BLOB field.
To re-read the geometries, use the GeometryReplacer, as Itay suggested.
David
vki
  • Jun 25, 2013 5:34 AM UTC
Thank you very much! Now I got my table with the SDO_GEOMETRY-field!
Vera
In my case I have oracle spatial relational writer and I need to have the SDO_GEOMETRY and other applications are reading it.
Am I using the wrong writer? Why is this SDO_GEOMETRY field missing?
Regards
