Models in COLLADA and OBJ formats can not be selected separately in FME
  • Nov 29, 2017 7:57 AM UTC
  • 71 views
The file formats for my model are COLLADA and OBJ.When I read the file with FME, I noticed that I could not pick a single entity on the model. The FME will automatically integrate the model into a whole, is it?In this case, my model exports files in other formats(as 3d tiles) via FME, and can I separately pick a single entity on the model?
Best answer by takashi
FME usually reads a COLLADA or OBJ dataset as a single feature, which could have either a single surface or an aggregate consisting of multiple surfaces. If you need to decompose the aggregate into individual surface parts, consider using the Deaggregator transformer.
  • Nov 29, 2017 10:51 AM UTC
