Merging text Files Many to One with one header
  • Aug 15, 2019 1:01 PM UTC
  • 146 views
I have some text files, same schema, to merge into one text.
How can I accomplish this without connecting each file one by one to the single output text file and keeping only the header from the first one?
e.g.
header_1
header_2
header_3
header_4
text_1
text_1
text_1
header_1
header_2
header_3
header_4
text_2
text_2
text_2
I want to exclude the headers from 2,3,4...files, so that i get:
header_1
header_2
header_3
header_4
text_1
text_1
text_1
text_2
text_2
text_2
Thanks.
Forum|alt.badge.img+63
If it's always the same number of lines for the header you can use one Textfile reader for the first one and a second one for all the other files, specify the second one to skip the first x lines of the input files (i.e. the header)
heidelbergh
You can read all the files at once using the "Select Multiple Folder/Files" option in the text reader . After that, you have to classify your data in type "header" or "content" by any criteria you have in your bussiness rule ( by prefix for eg). So you can use a duplicate filter to remove the header repetions.
Remove_Dup_Headers.fmwfile01.txtfile02.txt.
Hope it helps !!!
