Manipulation of an complex excel file
  • Sep 5, 2017 2:54 PM UTC
  • 7 replies
  • 117 views
delgadojeaneth
I am new in FME. I have an excel file, that have a complex format, because base on Sub-Area, I have to only take certain parameters to do calculations. For example, for sub-area P01 I should get: Total cost, A+B and T+U and the same for P02. Something important to mention is that I can have several subareas and grouping the data have been a challenge for the way that the I get the data.
I hope somebody can help me,
Thanks
danilo_fme
Forum|alt.badge.img+58
  • Sep 5, 2017 3:15 PM UTC
Hi @delgadojeaneth,
Could you share us a sample you excel?
Thanks,
Danilo
erik_jan
Forum|alt.badge.img+26
  • Sep 5, 2017 10:50 PM UTC
Checking out the FME Desktop training for Excel recorded training session could give you some additional ideas.
delgadojeaneth
Hi @delgadojeaneth,
Thanks,
Danilo
Hi Danilo,
Here it is the file test2.xlsx.
Thank you very much
fmelizard
Forum|alt.badge.img+22
  • Sep 11, 2017 6:17 PM UTC
Hi @delgadojeaneth, are you able to provide a few more details on your workflow? Can you provide an example of the input and expected output?
steveatsafe
Forum|alt.badge.img+16
Check the reply on danilo_inovacao comment's. delgadojeaneth has replied with the Excel File example.
gio
Forum|alt.badge.img+15
  • Sep 14, 2017 4:13 PM UTC
You can use variable setters to do that.
At the reader parameter set has filed name row to "no".
Test and set variable
if column A= sub area name then value = column B
Same for row total cost.
Then come the costs which u can use for instance stringsearcher regexp [A-Z]{1} and then set variable to column A and v
If all sub areas are stacked in same column range, then your done. If not then you must adres the columns with mod (nr-of-columns-per_subarea). Depending on how many you have you might want to turn the column letters to a value by concatenating the character codes.
  • Sep 15, 2017 2:20 AM UTC
Hi @delgadojeaneth, I would add appropriate Sub-Area Name to every data row and then create desired table with an InlineQuerier (SQL query statement).
You can use the VariableSetter/VariableRetriever to add Sub-Area Name to data rows, and modify field names with the AttributeManager if necessary.
Then, add an InlineQuerier and set SQL statement according to the requirement.
SQL Query Example
select * from (    select        "Sub-Area",        'Total Cost' as "Item",        "Cost",        "Labour Cost",        "Total",        "Volume",        "Total Cost"    from source where "Item" = '_total'    union all select        "Sub-Area",        'A + C',        sum("Cost"),        sum("Labour Cost"),        sum("Total"),        sum("Volume"),        sum("Total Cost")    from source where "Item" in ('A', 'C') group by "Sub-Area"    union all select        "Sub-Area",        'Q + S',        sum("Cost"),        sum("Labour Cost"),        sum("Total"),        sum("Volume"),        sum("Total Cost")    from source where "Item" in ('Q', 'S') group by "Sub-Area") order by "Sub-Area"
See also the attached demo: manipulate-complex-excel-table-example.fmwt (FME 2017.0)
Hope this helps.
