.las to stl
  • Mar 6, 2018 7:00 PM UTC
  • 156 views
@athorsby1
nathanatsafe
Forum|alt.badge.img+9
Hi @athorsby1, thanks for your question!
Could you elaborate a bit more on what you're trying to achieve with your LAS to STL translation? This is definitely achievable in FME. The STL writer should take a surface or solid geometry, which can be modelled from a point cloud. Check out the simple workspace template I've attached for an idea of how to set this up. And please comment if you have further questions.
Best,
Nathan
las2stl.fmwt
  • Mar 12, 2018 5:12 PM UTC
Nathan,
Have had mixed result with the desktop setup. One question: what measurement units may I choose? the one successful translation measured in meters not feet and Solidworks could not convert it.
  • Mar 12, 2018 5:13 PM UTC
Best,
Nathan
las2stl.fmwt
may I change output units to US Feet?
nathanatsafe
Nathan,
Hi @athorsby1,
The units should be defined by the coordinate system of your dataset. You may need to use the Reprojector to pick a coordinate system that uses feet instead of meters.
Hope this helps.
Nathan
