Issue with using the XMLUpdater transformer to manipulate Metadata
  • Mar 29, 2017 12:31 PM UTC
  • 9 replies
  • 153 views
I'm using the Esri Geodatabase (ArcSDE Geodb) reader with Feature Read Mode set to Metadata, to read in GEMINI metadata from SDE. I'd like to manipulate certain elements before sending the updated metadata back to the SDE feature class.
Using the XMLUpdater I've been able to amend the content for some elements, however I haven't had any success when trying to amend the revision date, as there are three different date strings all with the same XML path:
metadata/gmd:GEMINI_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:date/md:CI_Date/gmd:date/gco:Date
Currently none of them are getting updated on the output XML.
The different date types are differentiated in the gmd:dateType element, e.g:
<gmd:dateType> <gmd:CI_DateTypeCode codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode" codeListValue="revision">Revision</gmd:CI_DateTypeCode> </gmd:dateType>
Has any tried this before, or has any ideas for how to just update one of the dates?
Best answer by itay
Hi @katiem, this ws demonstrates how to update the date tag in your document.
The trick was to get the right syntax for the XML path
issue-with-using-the-xmlupdater-transformer-to-man.fmw
Hope this helps.
itay
Forum|alt.badge.img+19
  • Mar 29, 2017 5:05 PM UTC
  • Mar 30, 2017 9:07 AM UTC
Hi @itay that article is helpful for the general process thanks. However the issue we are having is that the XML path we want to update is duplicated in the metadata and we're not sure how to isolate the specific one we want to update. There are three elements within the metadata, each one has the same XML path and they are only differentiated in the contents of the <gmd:dateType> element...
itay
  • Mar 30, 2017 9:09 AM UTC
Can you supply a sample of the metadata?
  • Mar 30, 2017 9:19 AM UTC
Sure, this is the particular section.
itay
  • Mar 30, 2017 10:04 AM UTC
I actually mean a file...that way ppl can test different solutions.
  • Mar 30, 2017 10:49 AM UTC
Here's the file: metadata-date-question.xml
itay
  • Mar 30, 2017 1:41 PM UTC
Hope this helps.
  • Mar 30, 2017 3:45 PM UTC
Hope this helps.
Thanks that's exactly what I needed, we were missing the number in the XML path. Have loaded the updated metadata back into SDE successfully with the help of this article: https://knowledge.safe.com/articles/787/writing-xml-metadata-to-geodatabase.html
itay
  • Mar 30, 2017 5:12 PM UTC
Glad I could help.
