Is there a python library to make calls to a postgres db in a startup script?
  • June 30, 2014
  • 44 views
I found some documentation for import psycopg2 but when I try to include this in a startup python script on FME workbench 2014 sp2 it says that there is no module named psycopg2.  I am trying to read/write to a postgres db, more specifically i want to set a value based on a previous feature.  I believe that you cannot iterate features in a python caller.
Best answer by david_r
that is correct, psycopg2 isn't part of the default Phython install, you will have to install it yourself: http://fmepedia.safe.com/articles/How_To/Install-Python-modules-into-FME
But why not just use the FMEUniversalReader in the fmeobjects API? The doc is in <FME install dir>/fmeobjects/python/apidoc/fmeobjects.FMEUniversalReader-class.html
David
  • June 30, 2014
David
