Is it possible to convert Access .mdb to .xml format
  • Mar 17, 2016 7:55 AM UTC
  • 5 replies
  • 131 views
  • Mar 17, 2016 8:14 AM UTC
Hi
Sure, that is possible, although "XML" is a very broad topic... Either use the generic XML writer or, for more control, use the XMLTemplater transformer. FME also has several, format-specific XML-based writers, such as for KML and Inspire, so you might want to see if your needs are covered with those, it'll probably save you a lot of work.
David
  • Mar 17, 2016 2:07 PM UTC
OK thank you. Do you have any example I can use or any tutorial that might help me to proceed.
Thank you
Marc
  • Mar 17, 2016 2:12 PM UTC
Unless you need the output to conform to a specific schema (xsd), I recommend you start with the "Generate workspace" functionality in FME and take it from there.
This is a good starting point
David
deanatsafe
  • Mar 18, 2016 2:02 AM UTC
For an overview of your options for writing XML / GML, you might also want to take a look at: https://knowledge.safe.com/articles/918/writing-xm...
For more on XMLTemplater see: https://knowledge.safe.com/articles/974/creating-an-xml-document-in-fme-with-the-xmltempla.html
  • Mar 21, 2016 10:24 AM UTC
Thank you all for your answers. I'll come back to you again if needed.
Good day
Marc
