Is it possible to add a prefix for UUID field values?
  • May 8, 2018 8:51 PM UTC
  • 114 views
Error: Invalid content at [11,58]: cvc-datatype-valid.1.2.1: '5da6322c-9e7b-4e35-a604-e931d7f40072' is not a valid value for 'NCName'
Error: Invalid content at [11,58]: cvc-attribute.3: The value '5da6322c-9e7b-4e35-a604-e931d7f40072' of attribute 'gml:id' on element 'tran:Road' is not valid with respect to its type, 'ID'
Solution: If am editing the gml file line containing gml_id:5da6322c-9e7b-4e35-a604-e931d7f40072 to gml_id: "any_name"_5da6322c-9e7b-4e35-a604-e931d7f40072. Then it is not showing error. Features will be validated and successfully imported.How to rectify this other than editing manually.Please help. Thanks
  • May 9, 2018 3:41 AM UTC
Hi @vishnuedakkat93, if some elements in the GML document have "gml:id" attribute and you need to add an identical prefix to the value of every "gml:id" attribute, the XMLXQueryUpdater might help you. Assuming that an attribute called "_gml" stores the whole GML document, and  the version of GML is 3.2. If the GML version didn't match 3.2, need to modify the namespace declaration in the expression.
XQuery Expression:
declare namespace gml="http://www.opengis.net/gml/3.2";
for $x in //*[@gml:id]
let $newId := 'any_name_'||xs:string($x/@gml:id)
return replace value of node $x/@gml:id with $newId
Hi Takashi
I am so thankful to you. The specific issues has been solved. I used python for this.
Thank you for your help.
