Is FME able to read Civil 3D alignment station labels?
I'm seeing the following lines in the Translation Log:
AutoCAD Reader: Entity type of 'AeccDbAlignmentStationLabeling' found, but not supported. Skipping entity
AutoCAD Reader: Entity type of 'AeccDbAlignmentMinorStationLabeling' found, but not supported. Skipping entity
I'm reading a .DWG in as an AutoCAD Civil 3D format file. Am I interpreting this correctly that station labels are not supported by FME?
  • January 14, 2021
@sarahbalabanov​  Unfortunately, as of FME 2020, the FME AutoCAD Map 3D reader does not yet support AutoCAD Civil 3D alignment station labels.
chrbalm
Forum|alt.badge.img+8
  • July 17, 2024
Is this still the case, as we are receiving the same error code in 2023.1
AliAtSafe
Forum|alt.badge.img+22
  • July 22, 2024
Hi, @cbalmbra1.
FME doesn't currently support these entity types. We have this backlogged [FMEENGINE-68243] for possible support (with enough demand). Also, could we request from you sample data containing some of these entities? Thanks!
