Insert color in Attribute Names in XLS
  • Jun 23, 2016 1:44 PM UTC
  • 120 views
danilo_fme
Forum|alt.badge.img+58
Hello FME Users,
I need to put the color in Attributes Names in my XLS file. I saw the configuration in Output XLS, but it change the color all my columm:
The Line 1 is the Attribute Name
The Line 2 is the Value.
Thanks
Hi @danilo_inovacao
As far as I can tell, the color option applies to the column. There isn't a way to specify color for a particular row, or even a single cell. There is an enhancement request (PR#47193) so I have added your name to it. It is a high priority and targeted for FME2017 - but I can't promise that it will happen.
I can't really think of a workaround either. Maybe someone else has an idea for that?
Regards
Mark
danilo_fme
  • Jun 23, 2016 3:25 PM UTC
Hi @danilo_inovacao
Regards
Mark
hi @mark2catsafe thanks your quickly answer :)
That is a just doubt to clarify my customer. Its possible to use a template file ready with format color, all right?
Thanks
philippeb
Forum|alt.badge.img+23
  • Jun 28, 2017 8:19 PM UTC
Any news on this case in FME 2017?
Thanks!
mark2atsafe
Forum|alt.badge.img+59
Thanks!
Hi @philippeb
In this case, no news is bad news. It's been pushed back to FME 2018. Apologies for any disappointment and inconvenience this is causing. Hopefully it really will appear in 2018.
