How to insert geometry column into Oracle from SQL Executor?
  • Feb 20, 2020 2:26 PM UTC
  • 8 replies
  • 295 views
I am using SQL executor to perform insert command to insert table data into Oracle. I have a column with geometry and data type as SDO_Geometry in already existing oracle table. The current geometry I want to insert into oracle is in UTM format. I have converted it using geometry replacer and reprojector in my workspace.
SQL Executor is throwing an error with too long string literals and can not be inserted.
What is the way that I can insert geometry column with UTM coordinates into Oracle SDO_Geometry column?
Best answer by gauripearl
Geometry is safely added to Oracle from Oracle spatial object writer. I used Oracle spatial object writer to add geometry column into the database.
  • Feb 20, 2020 2:36 PM UTC
It's known limitation in Oracle that you cannot pass string literals longer than 4000 characters in SQL statements, and of course complex geometries can easily go above that limit.
Have you considered using the DatabaseUpdater rather than the SQLExecutor?
  • Feb 20, 2020 3:31 PM UTC
I want to insert data into oracle table. I can't see Database Upater have option for that.
  • Feb 20, 2020 3:35 PM UTC
Is there any way to insert geometries from sql executor.
  • Feb 20, 2020 3:46 PM UTC
Sorry, not sure how I got the idea that you were updating rather than inserting.
For simply inserting records, you should look at using the FeatureWriter, probably set to using the Oracle Spatial Object writer. Or have you perhaps already tried it?
  • Feb 20, 2020 3:53 PM UTC
I have tried Oracle spatial object writer and having issues with inserting another column for sequence so I am using sl executor.
  • Feb 20, 2020 3:56 PM UTC
Try using the SQLExecutor to get the next sequence value, then use that in the FeatureWriter. That should work (I've done it several times myself), and you won't need to jump through a lot of hoops to avoid the 4000 character limit in Oracle (I've done that too and it wasn't pretty).
  • Feb 20, 2020 4:11 PM UTC
Yes it worked using SQL Executor.
  • Feb 21, 2020 5:08 PM UTC
