how to find duplicate of specific column ?
  • Apr 20, 2024 7:04 AM UTC
  • 282 views
soly
Forum|alt.badge.img+3
Hello ,
i would like to find duplicate of specific column
As example
Column A contain
256789 - 4567
4567 - 256789
256789 - 4567
i would like to find all duplicate values at column A ,consider  the values as duplicated in case  a-b or b-a
i mean , 3 above values consider are matched .
the target to ignore order of each cell
How could I achieve it ?
thanks in advance
FME 2021
danilo_fme
Forum|alt.badge.img+58
  • Apr 20, 2024 1:08 PM UTC
Hello @soly
Yu can use the transformer DuplicateFilter.
Thanks in Advance,
Danilo
liamfez
Forum|alt.badge.img+44
  • Apr 20, 2024 2:44 PM UTC
These are the steps I used (FME 2021)
  • AttributeSplitter on Column A using the hyphen as the delimiter (trimming whitespace)
  • ListHistogrammer with the source being the list created by the AttributeSplitter
  • 2 ListConcatenators, concatenating both the histogram count and value
  • Matcher checking both the concatenated count and value attributes
This also works with more than 2 values in the cell.
liamfez
  • Apr 20, 2024 2:53 PM UTC
An alternative method would be to use a ListSorter, instead of the ListHistogrammer, and follow that up with one ListConcatenator before going to the Matcher.
Both methods worked when testing with your sample data, however results varied once I made the values more complex. You could test out both methods with your actual dataset to determine which is preferred.
