How to filter DXF elements into shape files of various geometry
  • February 21, 2020
  • 35 views
benvk
Forum|alt.badge.img+7
I have a DXF file containing many feature types, including points, polylines, polygons, text etc.
I want to extract the polylines into a shapefile of polyline geometry, and the points into a points shapefile.
I am having a hard time finding the transformer(s) needed to carry out this simple task.
Can someone please point me in the right direction?
Regards,
Ben
Best answer by arnovananrooij
Hi Ben,
You could use a GeometryFilter to split your features per geometry type into different streams.
Good luck,
Arno
arnovananrooij
Forum|alt.badge.img+5
  • February 21, 2020
Hi Ben,
Good luck,
Arno
itay
Forum|alt.badge.img+17
  • February 21, 2020
You can generate a workspace (CNTRL +G) and read the CAD based on its geometry, see the readers parameters for that option.
benvk
  • February 24, 2020
arnovananrooij wrote:
Hi Ben,
Good luck,
Arno
Perfect, thanks!
