how to extract a certain range of number from an attribute?
franco69
Hi all,
i know it will maybe an easy one….I’ve tried with substringextractor or with AttributeTrimmer as well but i couldnt reach the right result.
i have attribute like these for example:
he0_wasser_WSG_TK_20143_AGE_f_r01_231030 or
ni0_geobasisdaten_gemischte_industrie_gewerbe_flaechen_20256_AGE_f_r01_240118
i have to split in this case “he0” and “ni0” and write that in an attribute x
i have to split “wasser” and “geobasisdaten” and write that in an attribute y
i have to split “AGE” in an attribute…….and so on
now comes the challenge:
the text between “wasser” or “geobasidaten” and the 5digit number (20143, 20256) has sometimes 2 words, sometimes 3 or 5 words…..but i have to write the whole text in an attribute z….ho can i do that?
i am not so well in regexp…..so i ask here for help
Thank you
Cheers
Franco
Best answer by franco69
joepk wrote:
I would avoid intricate RegEx expressions. They are hard to debug and they do not work the same in every environment.
I have solved this using the following native tools:
  • AttributeSplitter splits attribute and puts every part between the underscores in a list item.
  • ListSearcher searches the list using RegEx for 5 digits and returns 5_digit_number_index.
  • ListExploder explodes list.
  • Tester filters out the first two elements (index 0 and 1) and all the elements that share the same index or higher as the 5_digit_number_index.
  • Aggregator (grouped by ID) aggregates all list features together and creates a new list (Generate List: z_list).
  • Finally the ListConcatenator creates the output string of all string elements between the first two elements and the 5 digit number.
That do the work for me….thank you….but the listconcatenator is not necessary because to concatenate the attributes inside the aggregator also do the work
thx a lot and cheers
Franco
tomfriedl
Forum|alt.badge.img+13
  • April 2, 2024
Use the StringSearcher. Params e.g.
Expression:
^(.*?)_(.*?)_.*?_(\d{5})_(.*?)_
Advanced > Subexpression Matches List Name:
listname
Test it and have a look at the list listname.
franco69
  • April 2, 2024
hmmm…..list was created but not right…….. fme_feature_type is the attribute to split
listname 0 is ok
listname 1 also ok
listname 2 should be Fliessgewaesser……….here in this case is only one word between second underscore and the 5 digit number (but there could also be 3 or 4 words)
listname 3 should be 20240 (is now listname 3)
listname 4 should be  AGE (is now listname 4) and so on
but we are on the way
Cheers
Franco
tomfriedl
  • April 2, 2024
tomfriedl
  • April 2, 2024
I see, you change your post.
My answer is an example. The work is your part.
joepk
Forum|alt.badge.img+20
  • April 2, 2024
franco69
  • April 2, 2024
tomfriedl wrote:
i know that this is only an example……..but i would need the part “gemischte_industrie_gewerbe_flaechen” also together in one list attribute
franco69
  • April 2, 2024
Franco
