How to execute a published work-space from Oracle
I got a workbench published to FME server as an Jobsubmitter service now i want to call or execute this work space from an oracle trigger which triggers after an update to that table.
Below is my function would be called from the oracle table trigger but i can't see the workspace execution has started or completed.
I got proper UTL_HTTP access to the user and no errors while executing the function.
Can anyone shed some light what is the proper way to achieve this?
CREATE OR REPLACE FUNCTION DBUSER.FME_CALL RETURN BOOLEAN
AS
message varchar2(20);
req utl_http.req;
BEGIN
message := '99999';
-- Call the workspace
req := utl_http.begin_request('http://FMEServer/fmejobsubmitter/training/xml2dwg.fmw','POST'); utl_http.set_header(req, 'User-Agent', 'Mozilla/4.0');
utl_http.set_header(req,'Content-Type','TEXT/HTML');
utl_http.set_header(req, 'content-length', length(message));
utl_http.write_text(req, message);
utl_http.end_request(req); return true;
END;
Thanks,
reachmj
itay
Forum|alt.badge.img+16
  • May 2, 2017
Possibly this artikel can shed some light on the procedure necessary:
https://knowledge.safe.com/articles/1098/single-edits-oracle-push-data-from-the-database-to.html
  • May 2, 2017
Thanks for this link but i got my logic from there itself..May be i need to look into the authentication while calling the web service i guess.
itay
  • May 2, 2017
kinda suspected that....yes that would be the first thing I would check
  • May 2, 2017
Check the FME Server log files, if the REST call was received there should be a trace in the fmeserver.log.
You are correct that authentication is necessary.
