How to disp[lay CSV file Name in CSV reader?
  • Apr 5, 2016 5:03 AM UTC
  • 238 views
HI,
I am using CSV Reader to migrate data into Smallworld. Actualy i have 11 types of CSV files names as
1. CSV point.csv.
2.CSv Road.csv
3.CSV park.csv
4.CSV building.csv
5.CSV pole.csv......etc
when i try to create CSV reader it displays "CSV"in CSV reader. As bellow
Actual name of the CSV file is "CSV pole.csv" but it displays only CSV.
I want file name in that reader. How can i get that csv file name on CSV reader. I want to configure all the 11 csv files in single workbench. How can i configure all.
Thanks in advance for your help.
Best answer by takashi
Hi @mahendra30627, select "Feature Type from File Name(s)" option in the CSV reader parameters dialog when you add the reader to the workspace.
  • Apr 5, 2016 5:30 AM UTC
Forum|alt.badge.img+54
  • Apr 5, 2016 8:48 AM UTC
Is it possible to set this as a default somewhere within FME?
  • Apr 5, 2016 12:26 PM UTC
Yes. Check the "Save as My Defaults" command in the bottom of the parameters dialog. I have set this when the default feature type name "CSV" has been introduced, maybe 2013 or 2014.
Thanks takashi
