How to convert DGN to DWG ?
Dear All,
I need a full video tutorial to convert objects on Micrcsation v8i software to Autocad software using FME software?
Someone did it, please guide me.
Thank you very much
Pham ngoc Quang
hkingsbury
Forum|alt.badge.img+54
  • April 10, 2023
If you're simply looking to translate between the two formats, then Quick Translator should lead you in the right direction
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop/QuickTranslator/Welcome_FME_QuickTranslator.htm
  • April 14, 2023
I have used it but the result is not as expected. Output products in Autocad format are completely different from input products in dgn format. can i send you the input format file on dgn?
