How to convert cityGML to Geodatabase?
  • Sep 27, 2018 2:33 PM UTC
  • 278 views
Hey there,
I need to convert a cityGML file to Geodatabase or just in a file to get the cityGML in Arcgis Pro.
I used a Workflow right from the internet. But the transformation failed.
I tried the convertions with this workflow
https://github.com/Esri/3d-cities-template/tree/master/Workflows/3DCityMaintenance/CityGML%20Tools
Yours sincerley
Tobi
Best answer by chrisatsafe
Hi @tobihog1991,
Have you tried using the CityGML to Esri File Geodatabase Template from the FME HUB?
The linked template reads in CityGML data and outputs a Geodatabase with feature classes for each building feature type (i.e. roof, wall, etc.) using a Feature Type Fanout.
Hope this helps.
- Chris
chrisatsafe
  • Sep 27, 2018 3:24 PM UTC
Hi @tobihog1991,
Hope this helps.
- Chris
