How to assign elevation variation from Lidar to shapefile / drap elevation on feature line.
  • Jan 20, 2015 7:28 PM UTC
  • 68 views
Line (ShapeFile)
Lidar (.XYZ)
I would like to have Z on the shapefile but split featureline when i have a difference (like 5m on Z) or simply put a Begining Z or End Z.
I would like to produce 3D feature and have the profile from this.
gio
Forum|alt.badge.img+15
  • Jan 21, 2015 5:31 PM UTC
You could use ContourGenerator to create contours from the Lidar points.
Then LineOnLineOverlayer or Intersector wiht the Lines from your shapefile.
( you might need a GeometryValidator after and if you use an Intersector)
gio
  • Jan 21, 2015 5:36 PM UTC
If u want to use a Begining and End Z you can use a AreaBuilder (before the intesector or LineOnlIne) and extract the bounds using a BoundsExctractor.
If u want all contours to be built to areas, you can use a Hullaccumulator, extender and intersector.
