How does an i3s terrain mesh replace terrain in a scene viewer?
  • Nov 15, 2021 9:19 AM UTC
  • 80 views
I have created a "i3s_terrain_mesh" out of a DEM. Following the description on
this page, the terrain mesh would replace the existing terrain in the scene viewer.
In case we talk about the ESRI ArcGIS Portal/Online Web Scene Viewer, how would that work?
As far as I understood, only elevation layers can take over this job when being added to the scene.
Even turning an input into an "i3s_terrain_mesh", we deal with an SLPK, that has to be shared and published on the Portal.
In a web scene, such an added SLPK is not interpreted as a layer that can be added to the "Ground" - replacing the default terrain 3d elevation coming from ESRI.
Have you any experiences with this?
nielsgerrits
Forum|alt.badge.img+67
Not much experience with the i3s format so I can't help with the terrein mesh question.
But if you need an elevation layer in agol, I do this using the following steps:
DEMGenerator to generate elevation raster.
FeatureWriter GeoTIFF (don't forget the parameter "Write Esri-Compatible Coordinate System")
Drag GeoTIFF in ArcGIS Pro.
Drag to Elevation layer.
Share as web layer which results in a hosted elevation layer.
  • Nov 15, 2021 11:09 AM UTC
Yes thanks, I know, this works really fine.
However, this page tells that such terrain mesh could replace that terrain in the scene viewer - behaving like an elevation layer.
I was wondering how this would work....
